#include <Multiplex7Seg.h>
byte digitPins[] = {9, 10, 11, 12}; // LSB to MSB
byte segmentPins[] = {2, 3, 4, 5, 6, 7, 8}; // Segment a to g
Multiplex7Seg::set(1, 4, digitPins, segmentPins); // Initialize
int x=9876;
Multiplex7Seg::loadValue(x);
Multiplex7Seg::loadValue(1234);
//---------------Bit of display (Transistor driver)---------
char digit1 = 10; //Display digit 1 (1000)
char digit2 = 11; //Display digit 2 (100)
char digit3 = 12; //Display digit 3 (10)
char digit4 = 13; //Display digit 4 (1)
//--------------Bit of segment-----------------------------
char segA = 2; //Display segment A to D2
char segB = 3; //Display segment B to D3
char segC = 4; //Display segment C to D4
char segD = 5; //Display segment D to D5
char segE = 6; //Display segment E to D6
char segF = 7; //Display segment F to D7
char segG = 8; //Display segment G to D8
char segDP = 9; //Display segment DP to D9
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(segDP, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
displayNumber(1234);
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS 1500
#define DIGIT_ON HIGH
#define DIGIT_OFF LOW
for(int digit = 4 ; digit > 0 ; digit--)
//----------Turn off all digits---------------
digitalWrite(digit1, DIGIT_OFF);
digitalWrite(digit2, DIGIT_OFF);
digitalWrite(digit3, DIGIT_OFF);
digitalWrite(digit4, DIGIT_OFF);
//----------Turn on the right segments for this digit
lightNumber(toDisplay % 10); // send number low digit to display
toDisplay /= 10; // shift next number
//---------------Add point at digit 2-------------------
if (digit==2)
{digitalWrite(segDP, HIGH);
{digitalWrite(segDP, LOW);
//---------------On display------------------
switch(digit) {
case 1:
digitalWrite(digit1, DIGIT_ON);
break;
case 2:
digitalWrite(digit2, DIGIT_ON);
break;
case 3:
digitalWrite(digit3, DIGIT_ON);
break;
case 4:
digitalWrite(digit4, DIGIT_ON);
break;
delayMicroseconds(DISPLAY_BRIGHTNESS); // Brightness 7-Segment Controlled
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
break;
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
break;
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
break;
case 3:
break;
case 4:
break;
case 5:
digitalWrite(segB, SEGMENT_OFF);
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
